TwinTurbo.NET: Nissan 300ZX forum - loose wire or break in wiring insulation causing a short
Subject loose wire or break in wiring insulation causing a short
Posted by doug8867 on April 22, 2008 at 9:53 AM
  This message has been viewed 115 times.
In Reply To prob went away. but its back. how? posted by tanatastic on April 22, 2008 at 09:41 AM
Message in the ignition switch. Vibrated itself into a position where it made contact or
the exposed wire wasn't shorting itself out and worked fine. Now it's back in a
position where it's shorting again. Probably need to check for continuity to the
ignition switch and check the switch itself which will be a bit of a pain. :-(
